Kokobanshee Posted February 27, 2020 Report Posted February 27, 2020 So my banshee has an over sized radiator, I don’t see any markings or names on it. I’m wondering how much coolant it takes, do I leave some room or fill it all the way? Quote
94Denger Posted February 27, 2020 Report Posted February 27, 2020 In general you want to fill a rad to the top unless you have an overflow. 50/50 coolant water mix. Quote
Kokobanshee Posted February 28, 2020 Author Report Posted February 28, 2020 My over flow is deleted. Thanks! Quote
hoppedupandcutdown Posted February 28, 2020 Report Posted February 28, 2020 Fill to just above the core tubes. Heat will expand any more than that and puke it out. 1 Quote
hoppedupandcutdown Posted February 28, 2020 Report Posted February 28, 2020 11 minutes ago, Kokobanshee said: My over flow is deleted. Thanks! You certainly still have a overflow, just not a recovery/reservoir tank. Quote
Kokobanshee Posted February 28, 2020 Author Report Posted February 28, 2020 Correct, it’s still under my seat just not running to anything Quote
Deets Posted February 28, 2020 Report Posted February 28, 2020 Anybody run the reservoir up front? I just got one of JDS relocation brackets. Quote
Keno Posted February 28, 2020 Report Posted February 28, 2020 Anybody run the reservoir up front? I just got one of JDS relocation brackets. I used to. But then I needed space for a battery and replaced the reservoir with a battery.Sent from my iPad using Tapatalk 1 Quote
94Denger Posted February 28, 2020 Report Posted February 28, 2020 I just let the overflow straw puke on the pipes, steam and smell let me know i'm running her too hot. Quote
