6 minutes ago, SKEETER said:
Yeah, thatll make a huge difference......
Have no idea, I’m new to banshees so I’m staying conservative and mostly just wingin it
7 hours ago, SKEETER said:
Hawg those bitchez out , trick racing #1 style~
Not changing port timing, just blending mostly. I did flatten out the entry of the trans a bit.
I’m impressed with your tool selection. Did you buy that as a kit?
i would recommend you make a template for your porting. Show your exhaust port. I’d like to see how much you’ve hogged out. You can safely remove more at your transfers and intake also, but I like that your playing it conservative.
concentrate on your port angles at the transfers
I Probly only raised exhaust 2 degrees, mostly to smooth out  the port and sleeve transition. I took a good amount out of lowers and definitely the secondary’s to improve entry.
Didn’t buy any of it as a kit, just been adding to it over the years.
  • Like 1
