Engine is making a ticking sound.
evyg
I have a 2004 banshee. Engine has good compression on both cylinders. But has a weird ticking sound when running. I took the flywheel cover off and put a stethoscope on the the crankshaft while manually turning the flywheel back and forth and you can hear the ticking sound clear as day...... what do you guys think it could be? Connecting rod bearings ? Any advice is much appreciated.
Sent from my SM-G950W using Tapatalk
  • 1 month later...
