375hp banshees Posted January 14, 2019 Report Posted January 14, 2019 When you lap a questionable crank/flywheel, do you use Loctite afterwards for insurance, or doesn't help ? Quote
97Screamer Posted January 14, 2019 Report Posted January 14, 2019 .Sent from my HTC One M9 using Tapatalk Quote
97Screamer Posted January 14, 2019 Report Posted January 14, 2019 Blue loctite won't hurt if you have reason to question the quality of the threads. I've never used loctite on a flywheel, I'm a torque to spec'er.Sent from my HTC One M9 using Tapatalk Quote
375hp banshees Posted January 14, 2019 Author Report Posted January 14, 2019 Threads are fine, just taper areas. Didn't know if 64040 would help or hurt on taper Quote
97Screamer Posted January 14, 2019 Report Posted January 14, 2019 Sorry, I misunderstood. I'd be afraid of pulling it back off with green loctite on the taper. Quote
ZillaFreak Posted January 14, 2019 Report Posted January 14, 2019 Shouldn't need loctite on the taper. Quote
375hp banshees Posted January 14, 2019 Author Report Posted January 14, 2019 Not if it was in good shape but it's not it's not on a banshee and hopefully i'll only need to pull it off if it spins again and it'll be loose at that point. Put red on it w/o lapping it or knowing it' history & it spun again...4 poke backfire Quote
ZillaFreak Posted January 14, 2019 Report Posted January 14, 2019 it is spinning, you need to lap it to make a nice clean taper between the two. Do not use loctite to fill in hole. If it is that bad, get a new flywheel or crank. Quote
375hp banshees Posted January 14, 2019 Author Report Posted January 14, 2019 Yeah i'm lapping it this time , just didn't know if the locktite would effect the bite ... He's not buying a new flywheel, already told me that so, we'll see Quote
375hp banshees Posted January 29, 2019 Author Report Posted January 29, 2019 I guess Polaris has tors too. ETC = tors Canadian speak ...probably common knowledge to Polaris guys. figured I'd share any way... 1/2 broken wrist , broken key & stuck bendix later but... Found it Quote
