Is anyone on the site running XRF nerfs and a DD style lockup? If so how the hell did you modify your shifter? I’ve already bent the shifter to go around the lockup but now the foot pegs can’t eveb install and if they could the lever can’t go down because it hits the frame of the nerfs ...
I will get some pics up for sure.
Picture this. I bent the lever around the lockup but now since the lever is bent right the assembly for the nerf bar foot pegs hit the arm so bad that assembly can’t be put on.
If the arm was not bent it would work
3a9468ed4458918c618455905bd05e13.jpg6aefed605700a05111640dcebe449eca.jpg5121b42bee739ef79a5f3ed969aee3af.jpg
Pic 1 shows a close up of the problem
Pic 2 shows the still how far off the bolt holes are and how much further it’s need to go up
Pic 3 broad view.
What would you do Tyler?
Can you unbend it and adjust it down using the threaded rod under the rear master cylinder so that it sits under the cover and closer to the engine? I have a DD lockup cover with different nerfs and the amount of threads i have showing on the brake master push rod are 1/3 the amount you have. Ill get a pic.
Here is what im talking about. My lever has also been notched by the person i bought the cover from to allow more clearance.
Dano, I was fucking with that rod last night before I came in and couldn't get it to move at all. Are you opening your bleeder valve when playing with it?
I will head back in tonight and try it
No i adjusted it earlier this week and after the jam nut was loosened i rotated the upper hex bar closest to the master which the threaded rod inserts. Its a 10mm
Dano, I think I just realized after watching a vid on youtube that I may have missed the top adjustment bolt under the rubber.  Shoulda used the manual.  I will report back tonight when I get back in the garage. Thanks
Had XRF nerfs. Didn’t like them at all. The biggest pain in the ass. Especially trying to get to the kicker and starting it. Everyone says “you get used to heal kicking” I didn’t expect it to be as bad as it was. Hated them and sold them right away.
Cant remember if it was XRF or Alba, but it was this issue I had on a friend's quad. Had to use my heel. Then the kickers got stuck in the heel guard. It was terrible.  I wouldn't use any nerf bars that didn't have extra clearance for kicking.
