I have a 421 serval and run a single 35mm keihin carb. Looking to go to dual carbs. I understand it will run alot better with duals. Suggestion on size and shop to buy from. Thanks for the help.
Edited by dalegoldston
What kind of riding do you do? Since its a serval I'll assume bottom and mid are important to you so I'd recommend PWK 33s. If I had to guess I would say FAST will be having a Black Friday 10% off sale as they had in the past which would be a good time to buy them.
I wouldn't be scared to get another 35 and run it since you already have one. If you decide to try 28's or 33's in the future you could always re-sell the 35's and get a smaller set if you wanted too.
If it were me Id just buy the extra 35 mm carb and filters and intakes from FAST like said above.  you bottom end will still be decent depending on your pipe choice.
only thing you will have to see if you have a problem with is the MPG, you will go through more fuel obviously
