Mid range stumble
So I had a shop give me keihin jets. 170 main, 55 pilot. Needle on second clip. 500 above sea level. 421 assassin, 38mm pwk carbs, cool head, cpi in frame, shearers. Anyways, I went riding and was lean as hell. Moved the needle to 4th clip and it helped but not much. My kx125 beat me in a race. Wtf?
Sent from my SM-N920V using Tapatalk
-did you pressure test the motor for air leaks because that sounds slightly rich for that setup. Also what needle
What is your compression/ fuel your running as well.  Ported motor?
Edited by Ayesully810
Yes. It's at 140psi. I'm unsure of the needle. And fuel is 93 octane mixed 32:1
I did not plug chop yet. It starts first kick. And a local company, c&m Powersports. He just googled cause he didn't know
Did you plug chop the main yet?
How does it start and idle with that pilot.  You should see what needle is in there. What shop provided you with jetting specs?
16 minutes ago, kawa110 said:
140 psi on the cylinders....
Did you pressurize the crankcase with 6psi for at least 6 mins?
he said yes before that im assuming that was to the pressure test question. if not then that is highly suspect because that jetting should be more than enough to put it in a safe spot
Looks like its says his pressure test read out at 140psi.......
Only reason i asked.
Can watch your shirtless video to see how it’s done
