Ayesully810 Posted May 30, 2018 Report Posted May 30, 2018 33 minutes ago, kawa110 said: Looks like its says his pressure test read out at 140psi....... Only reason i asked. Can watch your shirtless video to see how it’s done lol dude thought you were talking about him .. and OP im beginning to think that you dont know what a pressure test is because you keep saying your pipes are inframe cpi shearers lol those are 2 different pipes Quote
christoph.tamz Posted May 30, 2018 Author Report Posted May 30, 2018 I never tested and I don't know how to do that. Sent from my SM-N920V using Tapatalk Quote
christoph.tamz Posted May 30, 2018 Author Report Posted May 30, 2018 Does that help at allSent from my SM-N920V using Tapatalk Quote
christoph.tamz Posted May 30, 2018 Author Report Posted May 30, 2018 And you take your pressure tester and kick until it holds air to desired pressure and wait for your leak down. Sent from my SM-N920V using Tapatalk Quote
Ayesully810 Posted May 30, 2018 Report Posted May 30, 2018 (edited) No watch this that is a compression test, pressure test is for air leaks that cause lean conditions https://m.youtube.com/watch?v=2V219g-hjfI Edited May 30, 2018 by Ayesully810 Quote
Ayesully810 Posted May 30, 2018 Report Posted May 30, 2018 10 minutes ago, kawa110 said: Sully post a link to your shirtless video... Christoph, you replyed “yes” to pressure test, did the crankcase hold 6 pounds air pressure for at least 6mins? lol its hot in michigan also trying to show off for tyler Quote
christoph.tamz Posted May 30, 2018 Author Report Posted May 30, 2018 Don't hate not a pressure tester?Sent from my SM-N920V using Tapatalk Quote
christoph.tamz Posted May 30, 2018 Author Report Posted May 30, 2018 So that's not*Sent from my SM-N920V using Tapatalk Quote
Ayesully810 Posted May 30, 2018 Report Posted May 30, 2018 (edited) no sir that there is a compression tester, it tests the compression in each cylinder. That is important to know as well. What size domes do you have in? a PRESSURE TEST, is testing for air leaks. If you have a leak some where in the motor, it will run more lean. The bigger the leak, the more lean you will be (its okay to have a very small leak because most do but nothing crazy) Did you assemble the whole motor your self? who did your porting too? If you watch that slightly homo video i linked it shows what a pressure test looks like Edited May 30, 2018 by Ayesully810 Quote
special06shee Posted May 30, 2018 Report Posted May 30, 2018 this is a pressure tester. Cap off exhaust and plug one intake Quote
Ayesully810 Posted May 30, 2018 Report Posted May 30, 2018 Just now, special06shee said: this is a pressure tester. Cap off exhaust and plug one intake danco ftw! Quote
christoph.tamz Posted May 30, 2018 Author Report Posted May 30, 2018 I suck at life. Sorry guys. LolSent from my SM-N920V using Tapatalk Quote
Ayesully810 Posted May 30, 2018 Report Posted May 30, 2018 I bet special06 will sell you that tester Quote
christoph.tamz Posted May 30, 2018 Author Report Posted May 30, 2018 I'm sure I can make one. The plumbers and steamfiters have all thatSent from my SM-N920V using Tapatalk Quote
christoph.tamz Posted May 31, 2018 Author Report Posted May 31, 2018 18mil domes and ported for dunes. Sent from my SM-N920V using Tapatalk Quote
