gunnin4elvis Posted December 23, 2017 Report Posted December 23, 2017 Good morning gurus, lay it on me, do you run the vent or block it on your clutch cover? What is your opinion and why? Quote
spurdy Posted December 23, 2017 Report Posted December 23, 2017 Good morning gurus, lay it on me, do you run the vent or block it on your clutch cover? What is your opinion and why?Block it. Reason- not needed. Sent from my iPhone using Tapatalk Quote
IceracerX Posted December 23, 2017 Report Posted December 23, 2017 Block it. Too much hose to be messin with. Quote
gusto Posted December 23, 2017 Report Posted December 23, 2017 You guys just plug it with a piece of plastic or does someone make a plug for it? Quote
gusto Posted December 23, 2017 Report Posted December 23, 2017 Just seen the plug off kit. I’m going to use a piece of rubber for the clutch side and back of engine Quote
trickedcarbine Posted December 24, 2017 Report Posted December 24, 2017 Plug it. The crank case also vents under the rear engine mount. Quote
registered user Posted December 24, 2017 Report Posted December 24, 2017 8 hours ago, gusto said: Just seen the plug off kit. I’m going to use a piece of rubber for the clutch side and back of engine maybe im understanding u wrong but if you plug both vents u wont like the results. the trans and clutch area need vented. since they communicate with each other u can just use the vent at the rear of the cases Quote
gusto Posted December 24, 2017 Report Posted December 24, 2017 5 minutes ago, registered user said: maybe im understanding u wrong but if you plug both vents u wont like the results. the trans and clutch area need vented. since they communicate with each other u can just use the vent at the rear of the cases Do I need to run a hose up to the bars or can I let it hang? Quote
registered user Posted December 24, 2017 Report Posted December 24, 2017 u dont even need a hose if u dont want. but to the question just put the hose were ever is convenient Quote
JUSTWANNARACE Posted December 24, 2017 Report Posted December 24, 2017 take the whole clutch cover off and press the vent valve under the water pump cover and put a block off plate on it. Saves weight.. Quote
