oil change, recommended oil?
I want to change the oil in my 99 banshee I just bought. What is the recommended oil for it? I read that it takes a little under 2qts. I watched some youtube videos and saw all kinds of diffrent recommendations. I trust what the HQ says a lot more than youtube lol
Also doing a compression check when gauge gets here. Is there any thing else I should do since I just bought it as far as maintenance?
Takes 1.5L of oil.
There are many options, 10w30 (without friction modifiers) ATF Type F, Belray Gearsaver, 15W40 T5, etc.
Some say ATF will cause pitting of the gears.
Just keep the oil clean and really, all should be fine. I like Belray personally.
Thank you! On the Bel ray, what weight do you use? I found this http://www.belray.com/bel-ray-gear-saver-transmission-oil
it has 75w and 80w
Edited by ckylesworld1
I used both, which ever the local dealer has. Normally try the 80W
Great. Im going to order some. Is this the correct stuff?
https://www.jakewilson.com/p/4835/-/2344/Bel-Ray-Gear-Saver-Transmission-Oil-80W-1-Liter?gclid=CjwKEAjw3KDIBRCz0KvZlJ7k4TgSJABDqOK7rHR8Ae7YLdIrzw-i1E67TaLE4-zBSQu3COl_W1fkAxoCKWXw_wcB
Also what about coolant? How much does it take and does it use regular antifreeze?
