Derpy Drifter Posted February 25, 2017 Report Posted February 25, 2017 Hey guys, my friend was riding my Banshee last night and it randomly died. We assumed it ran out of gas because it was really low, we put gas in it but it won't start. There's no spark for sure, I can hold the spark plug wires while I'm kicking it and it doesn't shock me like it usually does. What else could cause the issue? Everything is plugged in, brand new wiring harness too and had been running amazing ever since I finished the rebuild Sent from my iPhone using Tapatalk Quote
RIPPIN' IT UP Posted February 25, 2017 Report Posted February 25, 2017 Tors removed or still connected? Kill switch, ignition key bypassed, wiring harness modified? Info that needs to be shared before help can be given. Sent from my ZTE T84 using Tapatalk Quote
Derpy Drifter Posted February 25, 2017 Author Report Posted February 25, 2017 Tors removed or still connected? Kill switch, ignition key bypassed, wiring harness modified? Info that needs to be shared before help can be given. Sent from my ZTE T84 using Tapatalk I specifically said it has a brand new wiring harness. No tors, no parking brake, new key switch, stock kill switch. However I did find that 2 of my stator bolts had vibrated out despite using blue loctite. Anyway I got some new stainless Allen head bolts and used some blue sleeve retainer because it's a little stronger than the blue loctite. But still no spark Sent from my iPhone using Tapatalk Quote
RIPPIN' IT UP Posted February 25, 2017 Report Posted February 25, 2017 My bad missed the new harness bit, none the less the loose stator bolt will not help. Has there been any rubbing on the stator. Sent from my ZTE T84 using Tapatalk Quote
Derpy Drifter Posted February 26, 2017 Author Report Posted February 26, 2017 My bad missed the new harness bit, none the less the loose stator bolt will not help. Has there been any rubbing on the stator. Sent from my ZTE T84 using Tapatalk Minimal. My friend told me to check the ohms on the pick up coil so I'm going to do that as soon as I can find out what it's supposed to be Sent from my iPhone using Tapatalk Quote
trickedcarbine Posted February 26, 2017 Report Posted February 26, 2017 What's the pick up gap like? Quote
Derpy Drifter Posted February 26, 2017 Author Report Posted February 26, 2017 What's the pick up gap like? Forgive me for asking this idiotic question but that's the magnet thing on the outside of the flywheel right? Sent from my iPhone using Tapatalk Quote
trickedcarbine Posted February 26, 2017 Report Posted February 26, 2017 Yes, as in the pick up coil your buddy said to ohm. Quote
trickedcarbine Posted February 26, 2017 Report Posted February 26, 2017 It needs to be gapped around 18-20 thou. Quote
Derpy Drifter Posted February 26, 2017 Author Report Posted February 26, 2017 It needs to be gapped around 18-20 thou. Alright well it's definitely more than that right now Sent from my iPhone using Tapatalk Quote
hoppedupandcutdown Posted February 26, 2017 Report Posted February 26, 2017 Pickup coil should be 94-140 Ohms (white/red to white/green wire) Quote
hoppedupandcutdown Posted February 26, 2017 Report Posted February 26, 2017 check gap on the 2 nubs Quote
Derpy Drifter Posted February 26, 2017 Author Report Posted February 26, 2017 check gap on the 2 nubs Sent from my iPhone using Tapatalk Quote
Derpy Drifter Posted February 26, 2017 Author Report Posted February 26, 2017 Well I need a new pick up coil. I went to ohm it and as soon as I touched the one wire on it, it broke off. So I'm gonna get a new pickup coil, might as well get a stator and CDI too since I've replaced nearly everything else on this bike but those Sent from my iPhone using Tapatalk Quote
hoppedupandcutdown Posted February 26, 2017 Report Posted February 26, 2017 Don't buy cheap aftermarket junk. Quote
