Need to know if it is necessary to remove this allen screw to clean powervalve? It's hard to loosen and I'm guessing there's a reason for that, looks like if it got loose valve could hit the piston? Also can some one tell me which side goes down smooth or slotted? Thanks
Edited by Cali421
Cut away part of valve toward the piston. That screw is probably secured with high temp red loctite.
Edit: Cut away should be Away from piston and towards exhaust.
Yikes! I meant to say the cut part away from the piston. Yes the slots should go down.
As far as cleaning, I'm not familiar with the Trinity Power valves. I assume there is a bellow under that plate, or an oring on the sides that should be inspected. Definetely try asking @camatv
