Is your choke plunger assembly in good shape?
Did you ever check your bowls?
I run 25's with Toomeys and no lid
Same here. It's hard to start cold, but runs fine.
the choke tube in the middle is just a piece of hose someone cut and uses it slides on pretty easily idk if that can cause an issue or not. and idk if the bowls are on correctly or not. what's the way to tell?
Sent from my SM-G935T using Tapatalk
