Has anybody ever ran into there flywheel arching/gouging to the tapered section of the crankshaft? I'm just trying to figure out what's causing it on mine
Sent from my phone
Seen pics of them weld them selves to the snout and pull out some nice chunks.
As far as why? I'm not sure I luckily have never personally had an issue.
I think it's from not lapping the flywheel to the crank and it arcs. But hopefully someone smarter theN me has a proven answer
Lap it and coat the snout with blue loctite before install. I forget the terminology that describes the erosion of the metal due to that.
Its almost like the crankshaft is the ground and the stator is shorting out through it, I had a decent amount of water trapped in there after a race...
Sent from my phone
There was a member named Pappasmurf on here years ago with the same situation you describe. I remember he boxed it all up and sent it to Brandon at mull engineering. Not sure what the outcome was, but he may remember. .
I'll give mull a call and pick his brain
Sent from my phone
Wonder if it has to do with his whole grounding write up.
But since I read that, I run a ground from engine to chassis. Might help, might not. But it doesn't hurt.
My nology hot wires also have ground straps to the head.
I went to walmart and got a lawn mower starter cable. Was like 8 bucks, I think like 2 or 4 gauge with 2 nice eyelets.
Rob , I use locktite on all yours so u shouldn't see it . I believe electrolysis is the term your looking for . The flywheel creates a magnetic field
Yup that. Good, I hope to never have to open it.
But regardless, ground strap FTW!!! Cylinder base nut to engine mount on frame
Sent from my SAMSUNG-SM-G890A using Tapatalk
  • Like 1
hmm interesting.. ive heard people doing that ground strap just never knew why they bothered lol
Really only needed with pvl, IMO.
All grounds already go back to the same black wire. It's not like a car with a battery.
I stand by my stance that zero grounds are needed. No need to sand your pc or oven worry about the coil being grounded.
  • Like 1
