sheerider11 Posted July 12, 2016 Report Posted July 12, 2016 I will try and get a video of it when I get home. Im beginning to think its electrical too. Should I check the compression? I am its been bored to 65mm with the matching piston and rings. Could have somehow washed them out? It seems to idle well and start too easy to have low compression in my opinion. thanks for your input So is it reving or not? Your describing 2 totally different scenarios. First you say it revs and doesn't move Then it won't go over 25 Then it kind of sputters Quote
Cnelson47 Posted July 12, 2016 Author Report Posted July 12, 2016 Trying to tell you how it was acting and the steps I took to get to where it is now. The bike revs and moves. It is very slow and will not hit powerband Quote
Cnelson47 Posted July 12, 2016 Author Report Posted July 12, 2016 Prior to the new carbs the banshee was misfiring, sputtering and bogging badly. That has cleared up. Now it starts first kick and idles fine. Quote
Ayesully810 Posted July 12, 2016 Report Posted July 12, 2016 Trying to tell you how it was acting and the steps I took to get to where it is now. The bike revs and moves. It is very slow and will not hit powerband It might be best if you post a video of what your talking about it. Idk if its just me but Im having a hard time following what your saying. 2 Quote
Larry's Shee Posted July 12, 2016 Report Posted July 12, 2016 So how much time do you have on this build ?? How long did you run it with old carbs and shitty tune ?? Did this problem start suddenly or did it develops slowly over time? Quote
Cnelson47 Posted July 12, 2016 Author Report Posted July 12, 2016 This is at idle in the garage right now. Quote
Ayesully810 Posted July 12, 2016 Report Posted July 12, 2016 This is at idle in the garage right now. There is no video attached to this.. and imo the at idle part doesnt really seem to be the issue (someone chime in if im wrong) the issue that you keep trying to describe sounds like its when your ride (possible clutch slipping) post a video of riding. Quote
guns4children Posted July 12, 2016 Report Posted July 12, 2016 It must just be me but that thing sounds like it has a cold Quote
Cnelson47 Posted July 12, 2016 Author Report Posted July 12, 2016 Riding video will have to be posted tomorrow. Quote
Cnelson47 Posted July 12, 2016 Author Report Posted July 12, 2016 It must just be me but that thing sounds like it has a cold Haha I know. I wanna ride so bad too! Quote
Ayesully810 Posted July 12, 2016 Report Posted July 12, 2016 Is only one cylinder running?? Looks like one was running in the video Quote
Cnelson47 Posted July 12, 2016 Author Report Posted July 12, 2016 (edited) Is only one cylinder running?? Looks like one was running in the video Both are running. It's weird it's like it's poofs or something here and there on each cylinder Edited July 12, 2016 by Cnelson47 Quote
Larry's Shee Posted July 12, 2016 Report Posted July 12, 2016 When was last time oil was changed and what are you using ?? Quote
Cnelson47 Posted July 13, 2016 Author Report Posted July 13, 2016 Bel Ray gear saver. It's just been changed Quote
