Cnelson47 Posted July 12, 2016 Report Posted July 12, 2016 Hey guys I have recently came across a problem with my banshee after my pops and I put it back together. We have done a complete rebuild top to bottom this winter and when we started it up recently it doesnt seem to hit the power band. It makes a lot of noise, but doesnt go anywhere. Upgrades are as follows: Toomy T5 pipes Cool head with 21cc domes (new domes) Pwk 28s with 158 mains (new) V force 4 reeds Vitos trued and welded crank (New) Uni pod foam filters Port job 65mm pistons (new) All electrical components are factory oem, but have not been replaced as far as I know. I am at sea level: Hampton Roads, Virginia The banshee starts first kick and idles great. I just dont know what could be causing this issue. Mostly everything is brand new. Reeds have checked out fine. All help is appreciated! Help get me riding this summer! Quote
hercalmighty Posted July 12, 2016 Report Posted July 12, 2016 What do you mean by it makes a lot of noise but doesn't go any where? Are you saying the motor revs out but the quad doesn't move or that the motor doesn't rev out Sent from my VS990 using Tapatalk Quote
Cnelson47 Posted July 12, 2016 Author Report Posted July 12, 2016 What do you mean by it makes a lot of noise but doesn't go any where? Are you saying the motor revs out but the quad doesn't move or that the motor doesn't rev out Sent from my VS990 using Tapatalk I was saying it to be funny. It goes through all gears fine. The tors system has been deleted and rev limited is disconnected. Quote
hercalmighty Posted July 12, 2016 Report Posted July 12, 2016 Ok. Still doesn't answer my question. Is the motor reving out? Sent from my VS990 using Tapatalk Quote
Cnelson47 Posted July 12, 2016 Author Report Posted July 12, 2016 Ok. Still doesn't answer my question. Is the motor reving out? Sent from my VS990 using Tapatalk Yes, the engine seems to be reving out. Quote
hercalmighty Posted July 12, 2016 Report Posted July 12, 2016 Ok. Have you checked the clutch? Maybe it's slipping? What do your plugs look like? Sent from my VS990 using Tapatalk Quote
Cnelson47 Posted July 12, 2016 Author Report Posted July 12, 2016 Ok. Have you checked the clutch? Maybe it's slipping? What do your plugs look like? Sent from my VS990 using Tapatalk Havent looked into the clutch. I just jumped the carb jets up to the 158 mains to richen it up because I thought it was too lean myself. Now they have cardboard color look. Quote
sangheraent Posted July 12, 2016 Report Posted July 12, 2016 how old are the powerbands? did you check tension? Quote
hercalmighty Posted July 12, 2016 Report Posted July 12, 2016 Does it run better with the bigger mains? What size pilots do you have? Sent from my VS990 using Tapatalk Quote
Cnelson47 Posted July 12, 2016 Author Report Posted July 12, 2016 how old are the powerbands? did you check tension? Tbh I have no idea how to check for the powerband. Ill have to pull out the clymer manual and read up on it. Thanks for your input. Quote
hercalmighty Posted July 12, 2016 Report Posted July 12, 2016 Tbh I have no idea how to check for the powerband. Ill have to pull out the clymer manual and read up on it. Thanks for your input.Are you serious? Sent from my VS990 using Tapatalk Quote
Cnelson47 Posted July 12, 2016 Author Report Posted July 12, 2016 Does it run better with the bigger mains? What size pilots do you have? Sent from my VS990 using Tapatalk Yes it seemed to clear up a little more. It was backfiring and making a poofing noise before I ordered the carbs. Have to check on the pilot sizes and get back to you. I ordered the pwks from carb parts warehouse and they put them together based on my mods. Quote
Cnelson47 Posted July 12, 2016 Author Report Posted July 12, 2016 Are you serious? Sent from my VS990 using TapataLK Im kinda new to this. Doubt there is actual bands. Im pretty sure he is messing with me lol Quote
hercalmighty Posted July 12, 2016 Report Posted July 12, 2016 Ahhhh, yeah. Sent from my VS990 using Tapatalk Quote
Cnelson47 Posted July 12, 2016 Author Report Posted July 12, 2016 Ahhhh, yeah. Sent from my VS990 using Tapatalk I tried to be a smartass but yah know haha Quote
