For Sale - 99 Banshee.  This was a complete tear down and rebuild / restore project I finished in 2011.  I am going to offer it up for sale complete first and if there is no interest then I will part out.  I am asking $6000.00 complete, I know that I will never re-coupe all the money that was put into this as I have over $9K invested but you could not build this for $6K.  I am selling because I just do not hardly use it.  It gets used once or twice a year, so really just drain the old race gas and put in fresh and that is the extent of the use it gets.  Here is a list of what it has, I am sure that I am forgetting some things.
Motor: 99% of parts purchased from Kevin Herr @ Herr Jugs Racing
421 – Cub Stage II Mono Block
4-mill Hot Rod Crank
Wiseco Pistons
HJR / NOSS Cool Head W/ 21cc Domes
Port Matched Cases
Chariot Billet Intake with Internal Crossover Tube.
Chariot Billet Reed Cages with Boyesen Reeds
35 MM PWK Carbs
Chariot Billet Impeller
Chariot Timing Plate
Mull Engineering Billet Water Pump Drive Gear
Shift Star
Pro Mod Trans
Clutch Saver Pancake Bearing
Barnett Billet Clutch Basket
HD Clutch Kit w/ springs
All Cases are Powdercoated
Pipes: Rocket Pipes with modified Silencers and Trinity Spark Arrestors
A-Arms: American Star +2 up 1
Swing Arm: American Star +4
G-Force Axle + 4
Renthal Fat Bar Handel Bars
ODI Grips
Streamline Billetanium Hydraulic Clutch Kit – w/ ARC Lever
Works dual rate front shocks
Rear shock was rebuilt and re-valved with Eibach spring upgrade by Matt at So Cal Suspension
Jettrim seat cover
Mod Quad Billet gas cap
Entire quad was disassembled (Everything!)  If it could be powdercoated it was, even down to the brake calipers.
The downside is that I do not have a title if that is important to you.  If not, you can save yourself the tax money.  I am located in Northeast Ohio.  If your are interested or have questions call or text.  330-Seven-Eight-Zero-5-Seven-1-Eight
Marc
Thank you for the compliments!  It was fun to build and real fun to ride.  Just getting older (Did not say I was old!) and had enjoyed a Redline Revolt for all my dune riding, sold that and picked up a YXZ so I just don't use the Banshee.  If it sells I will invest in a turbo kit for the YXZ.
  • 1 month later...
It is still for sale.  If there is no interest I am going to start parting out at the end of the month.  Shame really, it is super clean.
If parted out price on the trans
Sent from my SM-G930P using Tapatalk
