About SheeMonster
- Birthday 02/21/1970
Contact Methods
Website URL
http://www.hallmanboostcontroller.com
Gender
Location
Ohio
Interests
Quads, Turbo Cars, Movies, Computers, Wife, 2 Sons, Family.
My Banshee (optional)
99 Banshee - Got it Cheap - Used - Not Well Maintained. 2009 / 2010 Winter Total Restoration Project.
Recent Profile Visitors
SheeMonster's Achievements
Just a quick follow up. This Banshee is still for sale. I have just rebuilt the top end so everything is fresh. New pistons, new rings, and I had the monoblock stripped and re-plated. During the course of an offer the potential buyer had requested a cylinder pressure test. Upon testing the results were 135 and 140 PSI which was low for 20 CC domes. Talked to Kevin at HJR and he said it should be 170 in good new condition. So I pulled the monoblock and sent it to him for inspection. He reported back that the plating was slightly out of spec but in good condition and I could just change the pistons and rings. Since it was off and he had it I decided to have it re-plated so that it was in perfect spec too. I have all the parts back and it is together and running. I am going to lower the asking price to $5200 or best offer. It is a nice clean Banshee with a new top end in it now... Below are a few pictures of the new internals. The only thing that is different is that the monoblock is no longer polished due to being stripped. Call or text if interested: 330-780-5718 Marc.
For Sale - 99 Banshee. This was a complete tear down and rebuild / restore project I finished in 2011. I am going to offer it up for sale complete first and if there is no interest then I will part out. I am asking $6000.00 complete, I know that I will never re-coupe all the money that was put into this as I have over $9K invested but you could not build this for $6K. I am selling because I just do not hardly use it. It gets used once or twice a year, so really just drain the old race gas and put in fresh and that is the extent of the use it gets. Here is a list of what it has, I am sure that I am forgetting some things. Motor: 99% of parts purchased from Kevin Herr @ Herr Jugs Racing 421 – Cub Stage II Mono Block 4-mill Hot Rod Crank Wiseco Pistons HJR / NOSS Cool Head W/ 21cc Domes Port Matched Cases Chariot Billet Intake with Internal Crossover Tube. Chariot Billet Reed Cages with Boyesen Reeds 35 MM PWK Carbs Chariot Billet Impeller Chariot Timing Plate Mull Engineering Billet Water Pump Drive Gear Shift Star Pro Mod Trans Clutch Saver Pancake Bearing Barnett Billet Clutch Basket HD Clutch Kit w/ springs All Cases are Powdercoated Pipes: Rocket Pipes with modified Silencers and Trinity Spark Arrestors A-Arms: American Star +2 up 1 Swing Arm: American Star +4 G-Force Axle + 4 Renthal Fat Bar Handel Bars ODI Grips Streamline Billetanium Hydraulic Clutch Kit – w/ ARC Lever Works dual rate front shocks Rear shock was rebuilt and re-valved with Eibach spring upgrade by Matt at So Cal Suspension Jettrim seat cover Mod Quad Billet gas cap Entire quad was disassembled (Everything!) If it could be powdercoated it was, even down to the brake calipers. The downside is that I do not have a title if that is important to you. If not, you can save yourself the tax money. I am located in Northeast Ohio. If your are interested or have questions call or text. 330-Seven-Eight-Zero-5-Seven-1-Eight Marc
Stock Banshee Head For Sale $50.00
SheeMonster replied to SheeMonster's topic in For Sale - Parts & Accessories
Ok Guys! Point taken... Just found it sitting in the basement and had no use for it. Obviously, no one else does either. -
I have a stock Banshee Head that is in very good condition. Not your typical filthy, damaged, pitted head that you find on EBAY. This is ready to install. Here are a few pictures. I am Located in NE Ohio. I am asking $50.00 and will ship for that price. Call - Text - PM 330-780-5718 Marc
Hi guys, Looking for some recommendations for gearing. Current Mods: 421 Stage 2 Cub Motor - All parts from Kevin Herr - Should be in the 90HP range. Cut Trans - no override - Still a 6 speed. Looking to run a +4 swinger. 20 tires (8 paddle Hauler) I only have the 8 paddle as an option in the hauler with a 9 inch rim. Riding Types: sand, trail and hill climbing. I am not lookiing for a drag setup for the sand (may play a little with a drag or two but not my main interest). Any advise would be appreciated. Thanks.
