Shee_fast Posted March 25, 2016 Report Posted March 25, 2016 Ok so I was riding my bike after I put the motor together(got it in pieces). I was in 3rd and I had nothing...I noticed after I pulled the clutch cover off that the denten wouldn't got down to first.. So do I have a bad drum or forks? The trans looks good no missing teeth and the dogs look good still square.. Any input? Sent from my VS810PP using Tapatalk Quote
hoppedupandcutdown Posted March 25, 2016 Report Posted March 25, 2016 Were you spinning it while shifting? Quote
Shee_fast Posted March 25, 2016 Author Report Posted March 25, 2016 Were you spinning it while shifting?You mean tires? Sent from my VS810PP using Tapatalk Quote
hoppedupandcutdown Posted March 25, 2016 Report Posted March 25, 2016 if the chain is still on, yes Quote
Shee_fast Posted March 25, 2016 Author Report Posted March 25, 2016 Yes tires were kind of spinning....I was trying to plug chop when this happen Sent from my VS810PP using Tapatalk Quote
Shee_fast Posted March 25, 2016 Author Report Posted March 25, 2016 I pulled the motor out and it still won't move if I turn it by hand..should I get new forks and drum? Sent from my VS810PP using Tapatalk Quote
Shee_fast Posted March 25, 2016 Author Report Posted March 25, 2016 Sent from my VS810PP using Tapatalk Quote
hoppedupandcutdown Posted March 25, 2016 Report Posted March 25, 2016 I meant rotating by hand while trying to shift by hand. Quote
Shee_fast Posted March 25, 2016 Author Report Posted March 25, 2016 No it won't spin once it hits seconds act like it's hanging up Sent from my VS810PP using Tapatalk Quote
Keno Posted March 26, 2016 Report Posted March 26, 2016 (edited) what won't spin? The transmission input and output shafts? or the shift drum? Use more words. Edited March 26, 2016 by Keno 1 Quote
87sheerips Posted March 26, 2016 Report Posted March 26, 2016 Bent shift shaft maybe. If this motor is still split in half, put cases together and spin output shaft as you shift thru the gears. As hooped up said 1 Quote
Shee_fast Posted March 26, 2016 Author Report Posted March 26, 2016 Bent shift shaft maybe. If this motor is still split in half, put cases together and spin output shaft as you shift thru the gears. As hooped up saidOk well I'll try that jd kinda looks like the shift claw won't hit star all the way.. Sent from my VS810PP using Tapatalk Quote
sheerider11 Posted March 26, 2016 Report Posted March 26, 2016 Ok well I'll try that jd kinda looks like the shift claw won't hit star all the way.. Sent from my VS810PP using Tapatalk That happens with no clutch cover on. The cover has a spot on it that holds the shift shaft tight Quote
Shee_fast Posted March 26, 2016 Author Report Posted March 26, 2016 That happens with no clutch cover on. The cover has a spot on it that holds the shift shaft tightAhh I see well if I hold the shaft and shift thru the gears with no trans in it works fine...but when I put the trans in it won't shift past 2nd...bad fork maybe? Sent from my VS810PP using Tapatalk Quote
edgehanger Posted March 26, 2016 Report Posted March 26, 2016 Take the shift star stopper off, put the transmission back in and you should be able to go through all the gears pretty smoothly. If it hangs up while doing this then the offending part should be easy to spot. With both tranny shafts removed, the drum and the forks should all move freely Sent from my GT-I9500 using Tapatalk 1 Quote
