Plog chop
I have fmf gold series
K&N pods with outerwear
27.5 pilot
290 main
Needle in 4th position
No leaks
Compression is 112psi with snap on tester
3700 elevation and its 54°F
Air idle screw is at 2 turns out
There's no way you need 30 pilots for this set-up at 3700 ft.
You're 2 turns out on you air screws.
If you needed 30 pilots you'd be under 1 turn out.
What are you mixing your fuel with and what's your mixing ratio?
32:1 lucas super synthetic (for now) klotz on the way
Also it was 2 turns out at the moment of the plug chop which was looked lean
Edited by gcautosports
Is it hard to start when cold?
If your pilot is lean it should be lazy off idle when you snap the throttle open.
32:1 is rich for today's oil.
I've been running YamaLube 2R for 20+ yrs at 40:1 and never a lubrication failure.
Plus 16oz of oil to 5 gals is exactly 40:1.
I ran my current mods at sea level at Pismo with 30 pilots, clip in 4th groove and 310 mains.
Bottom end was lazy as fuck.
Moved clips to middle groove and man what a huge difference.
My recommendation to you is the following.
Mix fuel 40:1. << this means 40 parts of fuel to 1 part oil. You're essentially richening your fuel to air ratio and making your jets bigger.
Sync carbs with FAST Sync tool at idle and 5000 rpm.
Set idle to 1500 rpms.
Turn your air screws to 1.5 turns out.
27.5 pilots
290 mains
To do a proper plug chop you need a fresh set of plugs and a 13/16 wrench.
Warm motor up fully with old plugs.
Switch to new plugs and put old plugs in pocket.
Run motor WFO to the top of each gear and when you get to 6th, hold it for a couple seconds, then simultaneously pull clutch lever and kill motor.
Stop safely out of the way.
Pull plugs and put old ones back in.
Go to your work bench and cut the entire threaded portion off your new plugs.
You want a 2mm thick brown combustion ring of smoke around the base of the white ceramic.
27.5 pilots
290 mains
It is unless i pull the choke then on the 2nd kick
And when im crusing then snap the throttle it bogs a bit then rips and keeps ripping with no bogs...maybe it just hates it when i handle it like a pussy..who knows
  • 2 weeks later...
Plug chops are done WOT in every gear and hold 6th for a sec or two.
Simultaneously pull clutch and kill motor.
Safely stop and swap plugs.
This is a very safe and slightly rich motor here.
http://bansheehq.com/forums/index.php?/topic/186085-plugs/#entry1794800
Ive read how to exactly do a plug chop, and thats exactly what i did and hold 6th for 2-3 did the run twise with the same plugs
