Dan7305 Posted March 3, 2016 Report Posted March 3, 2016 So, I searched, but I think I have a unique issue. Recently bought a banshee, working on fixing it up. It had a bastard of a welded shifter on it, bought a used stock one off eBay, and the stock one points about vertical when the bolt is lined up with the groove in the shaft. So the shift shaft isn't clocked properly. I can grind in a new groove no problem, but how important is the clocking of the shift shaft? Should I tear it apart now, or will it be fine. Quote
Dan7305 Posted March 3, 2016 Author Report Posted March 3, 2016 I haven't really tried much, it will go into and out of first and second. The jugs are currently out being ported so I don't want to rock it too much and have the pistons moving unsupported. According to the previous owner it did shift fine. Quote
Bennett131 Posted March 3, 2016 Report Posted March 3, 2016 Just for shits and giggles, drain the oil and pull the clutch cover. Take pictures then post them here. Quote
87sheerips Posted March 3, 2016 Report Posted March 3, 2016 umm. Pivot the shifter 1-2 grooves down? Quote
Bennett131 Posted March 3, 2016 Report Posted March 3, 2016 It should have some adjustment up and down, he made it sound like its the only way it fits on the shaft. Quote
Juststrokeit Posted March 3, 2016 Report Posted March 3, 2016 Could the shaft be pushed off the eccentric screw on the other side? Causing it to be off now? Sent from my iPhone using Tapatalk Quote
Dan7305 Posted March 3, 2016 Author Report Posted March 3, 2016 Sheerips, I don't think 1-2 grooves will fix this. http://m.imgur.com/3P4tUwO And it's lined up on the shaft. http://m.imgur.com/evKhuXL Bennett, I'll get the picture this weekend. Just stroke, I don't have a clue, I've never had one apart so I don't know how it works. Quote
hoppedupandcutdown Posted March 3, 2016 Report Posted March 3, 2016 I'm thinking that is for a YFZ450 I know it is NOT for a Banshee 1 Quote
kawa110 Posted March 3, 2016 Report Posted March 3, 2016 I like the bastard shifter under the hammer......lol Who knows what else is in that bottom end..... it through chain wacked case, bent original shift shaft, got replaced with whatever fits. Tear it down....or Mickey mouse it now to tear down later Quote
Dan7305 Posted March 3, 2016 Author Report Posted March 3, 2016 Hopped up... Wait, that's not even a banshee shift shaft? Or it's not a banshee shifter? Kawa, yeah, looking at it the made the bastard shifter to fit this shaft location, then it hit on the foot peg, so they just took the peg off. My issue with tearing it down is that I don't really know how it's all SUPPOSED to be. I suppose I should pick up a repair manual. Quote
Dan7305 Posted March 3, 2016 Author Report Posted March 3, 2016 And how can you tell it's the wrong one? Quote
hoppedupandcutdown Posted March 3, 2016 Report Posted March 3, 2016 Your new (used) shifter is not Banshee Quote
Dan7305 Posted March 3, 2016 Author Report Posted March 3, 2016 Yay for eBay! So is the shaft at least correct? Quote
Dan7305 Posted March 3, 2016 Author Report Posted March 3, 2016 If the shaft is the right one, I'm going back to my original impression that the case has never been apart on this motor, just a quick hone and ring job to sell it to the kid I bought it from. Quote
