Buster91dg Posted February 21, 2016 Report Posted February 21, 2016 Seal is brand new oil seems to be seeping from in between the collar and shaft. Is there an oring that goes on the shaft that the collar goes against? Quote
Buster91dg Posted February 21, 2016 Author Report Posted February 21, 2016 This is all I'm seeing no oring Quote
trickedcarbine Posted February 21, 2016 Report Posted February 21, 2016 Just a seal. What brand seal did you replace it with? Takes some patience to get a new one in there with out any distortion. Use a little sheet metal screw to screw in to the old seal, and pull it with pliers. That keeps guys from prying it with a screw driver and marring the surfaces. Check that there aren't any nicks or burrs on the shaft before the next one goes in. Also, a little grease goes a long way. Quote
sleeper06 Posted February 21, 2016 Report Posted February 21, 2016 Hot rods sell the seal and new collar for like $20 . This way you know the collar is not the issue Quote
Buster91dg Posted February 21, 2016 Author Report Posted February 21, 2016 And like i said could it be from a worn collar? It is a 1990 Quote
Buster91dg Posted February 21, 2016 Author Report Posted February 21, 2016 Ok I'll check the hot rods site for the kit Quote
Buster91dg Posted February 21, 2016 Author Report Posted February 21, 2016 Ok should I bother replacing the seal it was part of the wiesco bottom end kit that I did 3 months ago maybe 6 hours of ride time on motor Quote
hoppedupandcutdown Posted February 21, 2016 Report Posted February 21, 2016 new collar = new seal Quote
Buster91dg Posted February 21, 2016 Author Report Posted February 21, 2016 Ok great I'll have to order does anyone have the link for the hot rods kit with collar and seal Quote
hoppedupandcutdown Posted February 21, 2016 Report Posted February 21, 2016 http://lmgtfy.com/?q=Part+%23%3A+OSK0042 1 Quote
trickedcarbine Posted February 21, 2016 Report Posted February 21, 2016 Weisco seals are janky as fuck! Quote
Buster91dg Posted February 21, 2016 Author Report Posted February 21, 2016 Where's does it say it's for a banshee I want to order it right nie Quote
