hoppedupandcutdown Posted February 7, 2016 Report Posted February 7, 2016 I'd put a proper TORS kit on it with separate idle screws so as not to rely on the cable for both. Quote
Horney Posted February 7, 2016 Author Report Posted February 7, 2016 my carbs look out of sync. would that affect it not to run at all. not even to hit. Sent from my XT901 using Tapatalk Quote
hoppedupandcutdown Posted February 7, 2016 Report Posted February 7, 2016 if the right one is completely closed, it won't run, yes. Quote
Horney Posted February 7, 2016 Author Report Posted February 7, 2016 synced them back. still not hitting at all Sent from my XT901 using Tapatalk Quote
hoppedupandcutdown Posted February 7, 2016 Report Posted February 7, 2016 ever actually check the pick up gap? Quote
Horney Posted February 7, 2016 Author Report Posted February 7, 2016 yes. it was within tolerance Sent from my XT901 using Tapatalk Quote
hoppedupandcutdown Posted February 7, 2016 Report Posted February 7, 2016 Man, this is tough. Just for shits and gigs, I'd pull the exhaust and check for blockage. Quote
Horney Posted February 7, 2016 Author Report Posted February 7, 2016 you don't even feel the half. I've never been this defeated at any engine issue. and I'm a mechanic on Chevrolets. I wouldn't think so because when it was running it was blowing/pumping out cold air out of that side Sent from my XT901 using Tapatalk Quote
hoppedupandcutdown Posted February 7, 2016 Report Posted February 7, 2016 I've never had a reed issue, so not your guy there. Quote
hoppedupandcutdown Posted February 7, 2016 Report Posted February 7, 2016 short of getting you another complete carb to try. Quote
Horney Posted February 7, 2016 Author Report Posted February 7, 2016 every reed issue I've ever had involved cracked and bent reeds. these reeds look perfect. its acting like its not letting any gas in. Sent from my XT901 using Tapatalk Quote
Horney Posted February 7, 2016 Author Report Posted February 7, 2016 I'm really considering a 2 Into 1 setup Sent from my XT901 using Tapatalk Quote
hoppedupandcutdown Posted February 7, 2016 Report Posted February 7, 2016 actually, you can switch them to test, just get a long hose for the choke crossover . Quote
Horney Posted February 7, 2016 Author Report Posted February 7, 2016 I would try that but its not been hitting at all recently. youre probably gonna think this is retarded but I go frustrated and loosened the reed screws a half of a turn to where the reeds has to allow gas in. put it back together and kicked it. pulled plugs they're wet. didn't hit. but if I had it tight and put a lid of gas in each cylinder. kick it. it runs for 2 seconds before dying. makes no sence Sent from my XT901 using Tapatalk Quote
Horney Posted February 7, 2016 Author Report Posted February 7, 2016 I had my friend who's a technician on Yamaha's who has his own shop up the road stop bye and he had his hand at going through and looking at everything for a few hours. he saying it has to be in due delivery. but cant be in the carbs. and he said the reeds look good. ran leak down and compression test again. both are great. he brought a set of stock carbs that we know run. and that also didn't work Sent from my XT901 using Tapatalk Quote
