I HAVE TO SAY I DONT KNOW  MUCH ABOUT IT SO HERE GOES MY QUESTION BUT FIRST I NEED TO EXPLAIN THAT IM BUILDING A COSTUM (MITO'S FRAME) SPORTBIKE THAT I WILL BE USING ON STREET , TRACKDAY (1/4 MILE) AND SOME RACE  TO.
Im LOOKING FOR  A GOOD BOTTOM END AND MIDDLE RANGE , A NICE TOP END WOULD BE NICE TO , I WHANT TORQUE AND SPEED. NOW THE QUESTION IS ,WHATS THE DIFERENCE OF A CHEETAH SUPER CUB ,CHEETAH ,CUB OR SERVAL CUB ?
THE OTHER QUESTION IS , WILL I HAVE LESS ENGINE REABILITY IN A +7MM 0R + 10 MM THAT I WOULD HAVE WITH A +4 MM ? FIRST I WAS THINKING ON A  421CC +4 MM BUT NOW I WHANT SOMETHING AROUND 500CC , PLEASE HELP ME OUT , I WILL APRECIATE , THANK TIAGO P
There was the pipe dream concept of using Powervalve Cheetah cylinders with a 4mm crank for 485cc's. Never really got off the ground floor though.
Hit up Rodger at Wicked Motorsports. He is actually building Banshee/RZ power plants daily for road bikes, and he makes some pretty cool machines.
Edited by trickedcarbine
Thanks i will definitly do that
I found this tranny thats exactly for the Cheetah kit that i whant "Banshee 350 472cc 1-3 Override Engine Tranny" and i read a bit but i dont know if i understand correctly , will this add more torque to my 1-3 gear ?
Edited by chavecas
If you want to build a road bike you don't want an over ride transmission. You would want a pro mod transmission
Sent from my VS990 using Tapatalk
Thanks bro ;) i will look for one, great help
override be good for a more drag orientated bike, you`d probably destroy first track day
thanks , i go with :
-pro mod transmission
-68mm +10 mil cheetah (dont know wich one yet buts that what i decided for now)
-zeeltronic ignition (Z-PSR-R01)
-Lock up Clutch or Uprated heavy clutc
-Con Rod
_Chariot Billet Intakes Crossover
-V-force 4
-38mm Keihin Air Strike
-Con Rod
-V-force 4
No point in Zeeltronic ignition if you aren't running factory RZ cylinders. Also, steer clear of the Air Strykers. Little more finicky then the PJ's IMO.
