The +2 is the height over oem/stock.
The +1 is foward, away from you 1"
You will appreciate at least +1 height and +1 forward at your height. I'm 5'9" and am setup at +2 +1 and really like it.
Also, are you having your pegs relocated from oem position? That has some effect too.
I really like my Faast Flexx bars. Worth the money imo.
How do those extensions make you feel more comfortable? It must be more ergonomically based I'm guessing. About the pegs.... not to familiar with this relocation mod. Peeps moving them back or forward? What stem you use? I'm thinking fireball or roll.
It's allows you to stretch yourself out and not be hunched up when riding. You gain quite a bit of comfort and control.
A lot of guys will have their pegs moved back about 2" and down 1" This improves comfort as well as overall balance quite a bit.
Ok, sounds like I'll get a +2+1 stem. What brand do you use? I'll check into that peg relocation.
My stem is a Laeger's with anti vibe mounts.
You have to keep in mind my whole chassis, suspension, step, ect is all Laeger's Pro Trax with 250R geometry, so some things are similar to oem, all of things are not.
Edit: Talk to Arlo about the peg relocation.
What is your plan for nerfs?
I'll call Arlo on Monday and see if he did the peg relocation. I talked to him a week ago and asked if I could mount nerfs. He said probably not, but with a little fab work, I could get them to fit properly. I'll get the AC nerfs with heel guard.
Yep, you definitely need to find out this detail.
My opinion and experience, it's definitely worth having the relocated pegs.
Am I missing something here.... if I run nerfs how is it possible to relocate pegs when they come mounted on the bars...
