The guy i bought the bike said they where ported for a 4 mill stroke...but then i took it apart and it was running a spacer plate...it was running wsm pistons i beleive they where cast and it had 22cc domes not sure what the squish measurments where
I got so frustrated with the bike i just tore the whole thing apart and started fresh...i got dragged by a stock crank banshee with mild port work and pipes...not even exaggerating he beat me by like 7 house lengths
  • Like 1
Nahhh but when i say my bike was slow thats an understatement...the bike had pretty good top end but no bottom or mid range...a banshee should be no problem to wheelie lol it took some weight and physical strength to get mine up on two wheels...i have seen stock stroke bikes haul ass but the one i was racing wasnt one of them mine was just extra slow
drag ports dont have much bottom end, but it should lift the wheels while on the pipe no prob
It doesn't have to be a drag port. People see boost ports and assume it must be.
For all you know the work was all done in the transfers and the exhaust was barley touched. Can you get measurments?
Also if there was a spacer plate all your ports were at the wrong height.
It had shelf domes. Do you know the compression?
