2005she Posted September 6, 2015 Report Posted September 6, 2015 Okay I have a problem and am wanting to fix but don't know what to do this is what happens: I will be on 6th gear at alittle less than half trotthle and ass soon I'm passed a little over half trotthle it will start bogging and eventually die and won't start anymore Than I'll let it sit for 5-7 minutes than I'll turn on Quote
hercalmighty Posted September 6, 2015 Report Posted September 6, 2015 What are your mods? Sounds like you might be running your bowls dry Sent from my VS980 4G using Tapatalk Quote
2005she Posted September 6, 2015 Author Report Posted September 6, 2015 Stock motor,vforce reeds,t5's,mikuni carbs clamp on k&n airfilters,and tors eliminator kit Quote
hercalmighty Posted September 6, 2015 Report Posted September 6, 2015 What's your jetting? Might want to do a leak down test Sent from my VS980 4G using Tapatalk Quote
sleeper06 Posted September 8, 2015 Report Posted September 8, 2015 Jetting damn close check float heights and do leakdown while carbs are off Quote
5150banshee Posted September 9, 2015 Report Posted September 9, 2015 Remove 6th gear and hit Rev limiter on 5th ... problem solved hahahahah Quote
Bennett131 Posted September 9, 2015 Report Posted September 9, 2015 Remove 6th gear and hit Rev limiter on 5th ... problem solved hahahahahNo such thing as a rev limiter. Quote
5150banshee Posted September 9, 2015 Report Posted September 9, 2015 No such thing as a rev limiter.Guess it's hard to read sarcasm and joking around. Quote
Bennett131 Posted September 9, 2015 Report Posted September 9, 2015 Guess it's hard to read sarcasm and joking around.I was being sarcastic too man, banshees don't have them but they do exist lol. 1 Quote
RollinRhino Posted September 9, 2015 Report Posted September 9, 2015 might be blown head gasket. Quote
machinegunbanshee Posted September 12, 2015 Report Posted September 12, 2015 Check all your fuel vent lines coming off the carbs and off the tank. Ill bet that it does the same thing if you let it sit and idle for a bit in nuetral. How long does it take you to get to 6th gear when this happens. Sounds like vapor lock and the bowls are being emptied. Quote
lil Doobie420 Posted September 12, 2015 Report Posted September 12, 2015 hmm. could be but i would still leak down test it to make sure. i always drill the gas cap out to be sure anyways. Quote
