2005she
Everything posted by 2005she
  1. can i still use the clutch cable tough .
  2. I want to geg rid of te parking break and i was wondering if i could use the same clutch cable and the same clutch lever or if i needed to get different ones
  3. Averege temp here is about 50*F
  4. Forgot to mention pipes o have toomey t5's
  5. I have a bored 0.40,ported and polished (nothing crazy),stock carbs with K&N pod filters,vforce 2 reeds, and stock head and stroke engine.My elevation is 1,726'.What should my jetting and what clip should i put on the needle?
  6. still got these?
  7. the parking break was stuck somehow but managed to fix it banshee runs all good now thanks for the help
  8. tors blqck box unplugged already will check parking break if that doesnt fix it i will do a compression test
  9. So a while ago i was going to go for a ride in my banhsee and ebrything was normal i turned it on second kick on a preety cold day more cold than usual and i just left it there to warm up for about 4-6 minutes and when i went to give it a littlr rev it will rev a tiny bit then start to bog so i thought maybe i needed more time to warm up so i left it another 5 minutes and the same thing happend and i just left it for another 5 mins and nothing so i hoped on it and tried to ride it but it will just bog so thats when i knew there was a problem so checked everything and it all seemed right it had a fresh gallon of gas and everything and the day before i was riding it and it was working perfect so i dont know what to do know.
  10. ok thank you very much
  11. will 9x8.5 wheels fit on 18x10x8 tires?
  12. Wheb i take off the E-brake thing located on the clutch lever do i need a new clutch cabel im thinking on replacing the stock levers with the ASV f3 levers.
  13. Were can i find myself vforce 2 replacement reeds.
  14. hey guys wanting to get new handle bars and was wondering if i can install pro tapers fat bar on a stock sterring stem.
  15. can i install pro taper fat bars on a stock steering stem?
  16. So that means I can buy the yfz shocks and the alba a-arms and not need to grind or do anything to my frame right
  17. If I purchase the alba a-arms can I also install the yfz 450 shocks without having to modify my frame
  18. Are you selling the front suspension
  19. But what if I still want to keep my key
  20. Would 18 inch long travel works shocks from a trx 250 r shocks fit on a banshee 350 with long travel a-arms
  21. Can someone please post a link redirect me were I can purchase v-force 2 petals
  22. If I install the pro taper bars fat bars with the Barpad will I need to install my key sloth somewhere else and I so where is the best spot
  23. Well it's becouse the previous owner installed the shitty hush kit on it and instead of putting the original tips he just went ahead and cut of the hush kit and know both tips are bent down and wobble a lot but, I will take the snap ring off and check if it has the o ring
