The newer master definitely moves more fluid which is needed when moving the extra piston in the caliper. It also allows for a much more progressive action which is much nicer then the all or nothing the stockers give ya.
I did the yfz caliper swap on my Shee this last spring, and I did not use the YFZ master cylinder. It works just fine with the stock Shee master.
I'm sure it does. But a guy blowing through a hose can work too.
It's the fact that it's better. If your going to upgrade why not do it 100% instead of 50% ?
Again, just another situation where people "think" something is just fine because it was better then what they had, but in reality, they have no clue just how much better it could be.
Real question is whats the best setup for the rear? Dont mind cutting out a new caliper stay. Been looking at front dirtbike calipers but not real hard. Im aware of the brembro,250r and old mindbender setup. Im looking for cheap, abundant and effective. Any thoughts
Edited by m671054
Ris & Mind Bender are junk. The front right yfz 450 caliper goes on with little work, laeger posted a 4 piston old school street bike caliper that required some custom parts. The 250r is also gonna require lots of custom parts as well.
Cuervo Racing has a new kit for the banshee that happens to come with everything to be bolt on. It is a BREMBO opposing piston caliper, stainless line for your requested length, proper caliper plate, and any needed hardware. It's Tits!
