Strm Trpr Posted August 4, 2015 Report Posted August 4, 2015 I'm going to install my new Fireball HD +2 swingarm and at the same time, I'm going to swap my Dominator RPM Axle off my 87 onto my 02 and I need a new axle lock nut.What do you guys recommend?I'd like a set it and forget it deal.Not something that's going to need regular attention. Cascadehttp://www.cascadeinnovations.net/store/store_View.cfm?STORE_AREA_ID=3&store_dept_id=6 LSRhttp://www.lsracing.com/yamaha-banshee-350-billet-locknut-yamaha-banshee.186.8.atv-utv-racing ModQuadhttps://www.rockymountainatvmc.com/p/733/15935/Modquad-Double-Locking-Axle-Nut RAD-LOChttp://www.radmfg.com/RAD-LOC-Axle-Nut-L4-p/rad-rl-4.htm Durablue Posi-Lochttp://www.durablue.com/prod_display/posi_-_lock_nuts/14/0.php.htm Eliminator Axle only. Durablue Banshee Axles and other manufacturer's Axles, I guess. Here's the Dominator RPM Pro-Loc Nut.https://www.team-rpm.com/yamaha-1/banshee-yamaha-atv-parts/lock-nuts.html Any other suggestions?My stock lock nuts are fine, just wanted to dress up the situation while I was in there. Thanks in advance!! Quote
m671054 Posted August 5, 2015 Report Posted August 5, 2015 I have a mod quad type one. Wont stay tight for shit. Not very impressed with that style. Quote
Deadbeat Posted August 5, 2015 Report Posted August 5, 2015 i like the Rad-Loc design, a proper nut, might be junk if the tolerances on the thread are shitty though Quote
Lowroll Posted August 5, 2015 Report Posted August 5, 2015 I just bought one from cascade. It is a modquad part. Haven't used it yet but the above post makes me wonder if I should even try. My stock axle nuts absolutely will not stay tight after a ride Quote
sheerider11 Posted August 5, 2015 Report Posted August 5, 2015 I just bought one from cascade. It is a modquad part. Haven't used it yet but the above post makes me wonder if I should even try. My stock axle nuts absolutely will not stay tight after a rideDo you know how to tighten the stick ones? It's a real pain in the ass. Almost need a degree to get it right. Quote
Lowroll Posted August 5, 2015 Report Posted August 5, 2015 Do you know how to tighten the stick ones? It's a real pain in the ass. Almost need a degree to get it right. We just backed them off, cleaned the threads, applied locktite and wrenched them. The previous owner tore them up, looks like he used a chisel to drive them loose and may have got it out of round, might be why they wont stay. Quote
sheerider11 Posted August 5, 2015 Report Posted August 5, 2015 We just backed them off, cleaned the threads, applied locktite and wrenched them. The previous owner tore them up, looks like he used a chisel to drive them loose and may have got it out of round, might be why they wont stay.thats why they loosened up. Need to tighten the first one. Then the second back the first one out I think no more then a quarter turn or something in to it all while with in there tq. specs and having no play Sent from my iPhone using Tapatalk Quote
Lowroll Posted August 5, 2015 Report Posted August 5, 2015 So do you think I should even bother with the 1 piece axle nut? I mean, its here. I was planning to just run it. Like I said, my outer axle nut right now is borderline destroyed. open end wrench wont fit it because of how badly the last guy tore it up. He destroyed most of the bike really. I'm doing my best to fix it all Quote
ban565 Posted August 5, 2015 Report Posted August 5, 2015 I have the cascade one and never had any problems. Quote
sheerider11 Posted August 5, 2015 Report Posted August 5, 2015 So do you think I should even bother with the 1 piece axle nut? I mean, its here. I was planning to just run it. Like I said, my outer axle nut right now is borderline destroyed. open end wrench wont fit it because of how badly the last guy tore it up. He destroyed most of the bike really. I'm doing my best to fix it allFuck the 2 stock ones. Anything is better then that design Quote
Strm Trpr Posted August 6, 2015 Author Report Posted August 6, 2015 Fuck the 2 stock ones. Anything is better then that design Thanks for all the input guys. What's the better design, and why do you say fuck the stock 2 nut design? I'll check the service manual and see what they recommend for tightening. Quote
Strm Trpr Posted August 6, 2015 Author Report Posted August 6, 2015 Here's what the service manual says. Shouldn't be a problem if one has the right tools. https://www.rockymountainatvmc.com/p/740/32089/Tusk-OEM-Axle-Nut-Wrench?v=236 Quote
kawa110 Posted August 6, 2015 Report Posted August 6, 2015 (edited) Stock is ugly and NEVER stays locked..... And need rear axle nut wrench Edited August 6, 2015 by kawa110 Quote
