I lose half a pound in six minutes I cannot find a leak anywhere squirted everything down next to submerging the motor underwater and cannot find any bubbles. Only thing is I did not have my primary gear torqued yet because my clutch and stuff was not on to hold it from turning to torque it down. Still though there was no bubbles around the primary gear at the time.
Edited by prb
Sometimes it leaks from the keyway groove in the primary. Check your crank seals, if it's none of that . Pressure test the coolant side to 16lbs maybe a head seating problem. Some say that's acceptable lose but if it's head it will get worse I don't let any motor leave me unless that needle doesn't move
I will check that also it has a cool head on it with all new seals the whole motor has new seals in it a new crank and Pistons. I will recheck it after I get my primary gear toward down tight
