jscharphorn Posted June 7, 2015 Author Report Posted June 7, 2015 what ever, I new you were trouble from the start, you've been around and I have seen how you treat everyone. Thanks for your opinion anyways. Quote
sprinklerman Posted June 7, 2015 Report Posted June 7, 2015 what ever, I new you were trouble from the start, you've been around and I have seen how you treat everyone. Thanks for your opinion anyways. Look bud. I went back and read some of your previous posts and questions to get an idea of what might be inside your realm of abilities. I did that before I posted the suggestion to consult your builder and trust his judgment. It was obvious from your previous posts you need help. Hence my suggestion. Quote
bigweav81 Posted June 7, 2015 Report Posted June 7, 2015 what ever, I new you were trouble from the start, you've been around and I have seen how you treat everyone. Thanks for your opinion anyways. Honestly, it's usually the biggest pricks that have all the info. Then you start realizing they aren't really that bad. sent from yo mammy house Quote
sprinklerman Posted June 8, 2015 Report Posted June 8, 2015 Honestly, it's usually the biggest pricks that have all the info. Then you start realizing they aren't really that bad. sent from yo mammy house In all honesty I wasn't trying to be a prick. I can be if he prefers.After reading some of his prior posts, I felt like the quickest, safest, most sure fire way to truly solve his problem , was for him to take advise from the guy who built the motor. Anything else for him (based on his prior posts) would be potentially very costly for him. And an exercise in futility. ........imho. Quote
bigweav81 Posted June 8, 2015 Report Posted June 8, 2015 In all honesty I wasn't trying to be a prick. I can be if he prefers. After reading some of his prior posts, I felt like the quickest, safest, most sure fire way to truly solve his problem , was for him to take advise from the guy who built the motor. Anything else for him (based on his prior posts) would be potentially very costly for him. And an exercise in futility. ........imho. I was just saying that it seems like the people who aren't on here a lot automatically assume someone is being a prick. Lol, wasn't calling you a prick sprink. sent from yo mammy house Quote
sprinklerman Posted June 8, 2015 Report Posted June 8, 2015 I was just saying that it seems like the people who aren't on here a lot automatically assume someone is being a prick. Lol, wasn't calling you a prick sprink. sent from yo mammy house I know. But you wouldn't be wrong if you did. 2 Quote
jscharphorn Posted June 8, 2015 Author Report Posted June 8, 2015 enjoy, I am done with this thread 1 Quote
RadarRacing Posted June 9, 2015 Report Posted June 9, 2015 I hope guys that read this know that a not jetted right 421 cub, with not much timing, with the wrong thickness base gasket will bog. Thats the moral of the story there. Cubs and anything with high porting will not be happy with one or two things slightly off. If it has .040 squish with a .020 base gasket then that is honestly the biggest issue in my mind. 1 Quote
RadarRacing Posted June 11, 2015 Report Posted June 11, 2015 Looking at my notes , I had a .020 base gasket on my 421. Hopefully it is just carb jetting , otherwise I would swap some ignition components. Definately check needle and low to mid jetting. Quote
jscharphorn Posted June 12, 2015 Author Report Posted June 12, 2015 Yes all OEM ignition, problem has not been resolved yet, checking clutch set up next and installing a lockout. seems to run the best so far with 152 jets and 45 pilots but still will not launch from a dead stop with dirt tires. Sprinkles, you can keep your comments to yourself if you can control yourself. Quote
Surfrjag Posted June 12, 2015 Report Posted June 12, 2015 152? Did you check squish? Whats wrong with more timing? Quote
jscharphorn Posted June 12, 2015 Author Report Posted June 12, 2015 I am going to be checking squish today and have not tried more timing yet. and yes with 152 it rips, I called Fast and they recommended 152 as well. I have not done a plug chop with the 152 yet. Yesterday was test and tune at the track so I brought my yfz and was pleased with running a 5.09 for my best time, I am hooking to hard and wheeling, I do not have a wheelie bar. Quote
RadarRacing Posted June 12, 2015 Report Posted June 12, 2015 (edited) 170 mains is still too lean, I do not have a 172 so I need to order them and I am going to order the DEK needles, Will that change the jetting ? 170s too lean you say but ran better with 152s? This makes no sense. Do a good plug chop and post a pic. Edited June 12, 2015 by RadarRacing 1 Quote
sleeper06 Posted June 13, 2015 Report Posted June 13, 2015 That carb is def not sized rite for that motor , I guess the signal is the reason it wants such small jets 2 Quote
