I have trouble with my hole shot, it just bogs most of the time and the drags are next week and at the moment I will have to bring my 4poke because this thing is not going to cut it.
I am trying to take off in second gear
I have a 421 cub, 33pwk carbs on 110 mix is 32:1 jetting 170 mains 600' elevation.
 sprockets 15/43
22" tires
I have tried a bunch of different gearing and some different jets, needle is currently 2nd from bottom.
any suggestions ?
It seems everything I have tried does not work.
Compression seems low to not be ported, maybe shees tired. Who cut domes. What needle is in the bike I found d-series needles work the best in Cubs with those carbs . Can you do a plug chop. How do plugs look . Those jets don't alarm me so much
Motor was completely disassembled and put back together by shawn at proformance prototype after I purchased it used.
I have +10 swinger
110 race gas
New drive line clutch , no lockout
I do not know what needles are in it,  I do not know how to tell .
I did a glug chop last night with 168 mains, to me it looks lean but I am going to have shawn look at it this weekend.
The needles are marked right near the clip.
The 2 cubs I just tuned both wanted 160 mains. Anything bigger was a big loss in power. Did you check squish?
Bump the timing at least and try again.
Each bike is different so before changing jetting I would check squish and needle. Check pickup gap and new plugs gapped. Then try again. Any idea what base gasket?
I think your crazy to not have a lockout, I have a decent amount of experience with 33s they like bigger jets than the more common 35s . My friends duneport stock cylinder chopped perfect at 172 main dek needle 2nd clip
needles are OG
plugs gapped at 22, I have tried new plugs also.
squish and gaskets I will need to ask shawn.
pistons and rings were good he said so we used them.
I will talk to shawn tonight.
was your friends clip 2nd from top or bottom ?
