quickbansheeman Posted May 31, 2015 Report Posted May 31, 2015 Does the stator magneto still look usable? Can I bend those bent one back? Quote
sleeper06 Posted May 31, 2015 Report Posted May 31, 2015 You can bend them back , it's not easy and u risk damaging one of the circuits. Take ohm readings of circuits before u bend and after to make sure u don't damage anything. If you crack the epoxy coating get some liquid electrical tape and liberally apply it, let dry and your good Quote
sheerider1026 Posted May 31, 2015 Report Posted May 31, 2015 Try to get them back straight. Don't want them outta phase. Man. How the hell did that happen? Quote
sheerider11 Posted May 31, 2015 Report Posted May 31, 2015 Try to get them back straight. Don't want them outta phase. Man. How the hell did that happen?I'm thinking stick something through flywheel to hold in place Quote
joshuamstevens Posted May 31, 2015 Report Posted May 31, 2015 Do yourself a favor and buy a new set up. Quote
quickbansheeman Posted June 1, 2015 Author Report Posted June 1, 2015 The key fell off and wedged in there Quote
hoppedupandcutdown Posted June 1, 2015 Report Posted June 1, 2015 Might as well try to fix it, ain't out nothing. Quote
quickbansheeman Posted June 1, 2015 Author Report Posted June 1, 2015 I'm just trying to avoid paying so much for a new one. I've heard the Ricky stators aren't that good. Quote
hoppedupandcutdown Posted June 1, 2015 Report Posted June 1, 2015 If yours ends up not working out, someone here can hook you up with a good used OEM one. The only way to go. Quote
joshuamstevens Posted June 1, 2015 Report Posted June 1, 2015 Off subject. Y'all ever experienced the banshee reverse bias? Kick a backfire motor and it spits in reverse? All of a sudden you have 6 reverse gears?? Lol Quote
Bennett131 Posted June 1, 2015 Report Posted June 1, 2015 When the timing is way off? Nope never heard of it. Quote
registered user Posted June 1, 2015 Report Posted June 1, 2015 (edited) how does the key fall out when it cant go forward or back. must of been you whole flywheel fell off is the only way. joshuamstevens will fix you up Edited June 1, 2015 by registered user Quote
quickbansheeman Posted June 1, 2015 Author Report Posted June 1, 2015 Idk, I just found the key when I pulled out the flywheel, n saw that, good thing i was changing the crank before I put the ported cylinders in there. Quote
quickbansheeman Posted June 2, 2015 Author Report Posted June 2, 2015 Just ordered the key, gonna try n bend it back, then we will see if it works once I have the quad all put together Quote
