joshuamstevens
Everything posted by joshuamstevens
  1. As you read. All good. Lights in on, no power after 30 seconds. Runs great with no lights.
  2. Banshee will run for 10 minutes then slowly loses power and dies.
  3. See that? First post, @zillafreak. No freakin respect. This website is nothing but immaturity stained with ego and semen.
  4. Fucking retards
  5. Washed it out. Zero friction upon thigh swipe now.
  6. Flywheel key is an OEM piece.
  7. You both bring up very relative points...
  8. Off subject. Y'all ever experienced the banshee reverse bias? Kick a backfire motor and it spits in reverse? All of a sudden you have 6 reverse gears?? Lol
  9. WWW.rg3rockford.com
  10. So when I try to give advice and everyone argues. I just laugh and get paid.
  11. This site is a joke. The only reason I signed up. Two customers bought shit off this site and brought it to me to fix. Cylinders scored and ovaled, ring gaps out of spec, stator lead output out of spec, and all of this because they followed advice from this site.
  12. About the same as every other post
  13. Well their ears are big enough to pick up on retoric.
  14. Nothing but arguments from kids who have never actually fixed anything.
  15. Trying to tune out burnt out rings never works.
  16. Service manual specifies, less than 120 psi....replace top end. And if you use stock b.s like Namura pistons/rings. You may still be at 120. But if you used any decent kit like pro x or vertex or wiseco, the dome is much more aggressive and you will have a 160+ comp reading.
  17. Why don't you explain in detail what y'all do for a hobby. I will explain what I do for a living.
  18. I just rebuilt this 4 mil stroker this weekend, dialed in carbs, had to run new stator leads box there was too much resistance in the lines. Ran rich, not due to jetting, due to weak spark, weak spark BC leads were overheated several times. I built it from a pile of parts.
  19. This is a post about advice. Not arguing.
  20. Guys shut the fuck up unless you have advice and stop arguing with me.
  21. Troll. Lol. Nl . Trying to give him advice. He has LESS than 120 in each cylinder AND he can't even hold 6 psi on a leak down....
  22. Guess what. If your banshee is running rich with stock jetting. Low compression. And this troll is working quite well.
  23. ^^Do you even know wtf that means??^^
