98 shee with fmf fatty golds and silencers
Bored .20
270 mains and 27.5 pilots
Tors delete
15 front tooth 41 rear sprockets
40:1 93oct amsoil dominator
Pep fronts shocks on the way
Its a trail bike so id like a lil more input on some more mods
Timing advance, vf4 reeds, and pods will help alot. Suspension is overlooked alot, but it's the first thing I'm doing this time around.
Sent from your mammy house
Good a arms
Good swing arm
Good shocks all around
Tight bushings
Tight tie rod ends
Good bearings
The shit that gets over looked. Like the rear shock hiem bearing things, the linkage bushings, swing arm bearings, stem bearing and seals, brakes not frozen, good rotors, and what ever else you can find. I see so many bikes that people have never serviced these parts. I try to make it yearly to change out these parts. If I have to think back to when I might have done it and can't remember then it's about time.
It gets expensive the first time to do everything but once done you'll see what last and what doesn't. Then you can figure out service intervals for stuff.
  • Like 1
I have a set of peps getting serviced from sf racing good dude. But its all beside a boost bottle. So should i change my cage then or put a spacer in it and what is the reason if so. I was thinkin a cool head that i can still use my head bolts with out taking them out
Nossheads are sweet I think. Turn your boost bottle into a bong, or throw it at a shitty neighbor.
  • Like 1
A arm bushings, hub bearings, carrier bearings, swing arm bearings, shit like that.
This is all shit you need to check. The motor runs fine right? I wouldn't fuck with it.
Chassis first then motor.
Check out site sponsor F.A.S.T. everything you need, including stock crossover tube. Sheerider11 is right though. Definitely upgrade chassis first. Its not cheap, but better to get it out the way right off the bat. Especially if you ride like lightning, and don't wanna crash like thunder!
