If you do swing arm or carrier brgs, put a grease zerk in it. Don't put the swinger right in the middle, hard to get at with shock in way. Coat swinger bolt with anti-seize. Same with axle where it slides through sleeve, same with a-arm bolts.
  • Like 1
Anti sieze is water based so i feel it would corrode in there could be wrong but my bushings all have zerks on them now i greased them and wiped excess off should i do anything when i put my front shocks on like as lube the eyelids or do they go in fairly nice
Im not against any of these i appreciate the input from everyone
I put never sieze on my jeep calipers and they corroded onme is all thats why i asked
Also gravel i ride tight trails with rocks and trees everywhere!!! I run holeshot 20s on the rear with ambush 21s on the front.....good combo? And also just the belly plate works well with the arm plates or do you have those also
Go wider, but decide soon, or your pep shocks will be set up wrong for the wider a arms
Sent from your mammy house
I live in ohio and im 1hr and r0 mins from baldwin racing but they wanted 300 for service and revalve for a set iwent with sf racing in illinoise for 160 a pair service and revalve but hes had them for 2 months now
This anywhere close to Illinois? Let me know how your shocks turn out.
