when the lower section of the yfz is done right instead of attempting to reuse the OEM frame mounts and the motor is up in the gas tank  there is a ton of room...  pipes are going to take a lot of work to get in there. unless your running some sort of single a-arm setup?
It may just be the angle of the pictures but way you have the a arms set up it looks like you will end up with way too much negative caster. Did you move the upper a arms forward to clear the pipes?
