Uf21 Posted February 23, 2015 Report Posted February 23, 2015 (edited) So riding season is coming up again. Banshee hasnt moved from its spot in over 8 months. What should be done to it before I start it? All I could think of is flushing the old fuel and flushing radiator. Is there anything else? Edited February 23, 2015 by Uf21 Quote
SAVAGE420 Posted February 23, 2015 Report Posted February 23, 2015 Grease it, go over bolts for tightness for shits and grins, tire air pressure. Check filters cleanliness, check for any rodents making it a home for the winter ect 1 Quote
trickedcarbine Posted February 23, 2015 Report Posted February 23, 2015 Check coolant, oil change, spritz of lube town the spark plug holes, check plug gap, pick up gap, clean carbs, fresh fuel. 1 Quote
Uf21 Posted February 24, 2015 Author Report Posted February 24, 2015 (edited) Thanks. Edited February 24, 2015 by Uf21 Quote
Uf21 Posted February 24, 2015 Author Report Posted February 24, 2015 Check coolant, oil change, spritz of lube town the spark plug holes, check plug gap, pick up gap, clean carbs, fresh fuel. When you say lube down the spark plug holes. Would a few drops of any car engine oil work? Quote
dirtydownunder Posted February 24, 2015 Report Posted February 24, 2015 id just kick is slowly a few times, then start it. Quote
Deadbeat Posted February 24, 2015 Report Posted February 24, 2015 ArmorAll the seat and grips and WD40 the brake pads 2 Quote
Burke Posted February 25, 2015 Report Posted February 25, 2015 light a few candles, get it some flowers and a box of chocolate wouldn't hurt if you want to speed things up a little... just get it drunk that should turn it on Quote
dankengineering Posted February 25, 2015 Report Posted February 25, 2015 ArmorAll the seat and grips and WD40 the brake pads its the the only way to properly lube your machine its how i do mine everytime.. Quote
Uf21 Posted February 25, 2015 Author Report Posted February 25, 2015 light a few candles, get it some flowers and a box of chocolate wouldn't hurt if you want to speed things up a little... just get it drunk that should turn it on In a dim lit room with rose petals leading to the candles and box of chocolates? Quote
