Banshee all of suddent runs like shit. Compression: L 147 PSI R142 PSI. When and if i can start it, it popes and smokes bad on left cylinder. It also has a bit of oil cominf out of the left pipe. If i start it and can keep it running it will pop and soon just bog and die. Reeds are fine. What should i do? I have noticed that sometimes i check spark and it doesnt have it and sometimes it does. Also have noticed a few grips of oil leak out the bottom of motor looks to be on the three cap nuts. Any advice helps
Edited by kryder
I'm guessing the build up of oil is from the lack of spark.
Have you checked to make sure the flywheel is seated properly and not loose? A loose flywheel will cause all kinds of issues.
Once you've determined that the flywheel is not the culprit, then I would move on to the electrical.
Have you checked the tabs that hold the coil on? they should be bare metal to help with grounding.
Generally the coil is either good or bad, I've never seen an in between.
The CDI can however produce intermittent spark.
Im about to insoect the stator and the electrical setup and i notice oil/gas is leaking out of the bottom of the motor. Looks like those bolts toward the front that go straight upward?
It's not leaking from the bolts, It's leaking off the bolts. Probably from the carb that is not feeding it's cylinder.
Try switching complete carbs left to right and see if your problem follows.
Also most stators look like that on bikes that are ridden in water, nothing leaking from the bike will cause that.
Flywheel keys look fine. What is the pickup spacing supposed to be? I also found out that the wire inside the plug wires was corroded and worn away. Switched carbs. Will run it later.
