hondaracing02 Posted February 10, 2015 Report Posted February 10, 2015 I have an 03 banshee that I was riding down the road when the clutch linkage (i believe that is what its called, the internet called it the push lever assembly.. its the piece the clutch cable attaches to that goes down into the motor and has a bracket that bolts down over top of it). either way it popped out of the motor and bent that bracket up when i tried to shift to 5th or so? now its all warped and twisted. (POSTED PICTURES) I ordered a new one and got it in the mail, but am not sure how to install it? When i watched an engine disassembly video, the guy just pulled it right out of the motor? I figured it would be connected to some sort of push rod or something? I do not want to split the cases to do so, but if I have to I will. Any help on how to replace this piece will be greatly appreciated! thanks in advance. Also, based on the picture of the old clutch linkage piece, i shouldn't have to worry about pieces down in the motor should I? Quote
trickedcarbine Posted February 10, 2015 Report Posted February 10, 2015 There is a seal, change that while you're in there. The clutch arm will just drop down in there. The retainer on top holds it in. (Why is there no retainer in the photo?)You should also do the clutch rod and ball. No splitting of the cases needed. Quote
hondaracing02 Posted February 10, 2015 Author Report Posted February 10, 2015 I took the little retained off becasue it was bent up. Will replace it. what seal are you referring to? the little black one below the spring type coil? also what do you mean by clutch rod and ball? Sorry to ask so many questions, just want to be sure to do it right! thanks for the help so far! Quote
hondaracing02 Posted February 10, 2015 Author Report Posted February 10, 2015 Found this on ebay. Wish I would have seen this before i ordered the one i have now not as a kit. That bearing must be visible if I pull out the seal? Quote
trickedcarbine Posted February 10, 2015 Report Posted February 10, 2015 Yes. Once the retainer is off the clutch arm can go up or down. But you also should have the clutch cover off and pressure plate loose. So the rod and ball can move forward while you drop the new arm down in. There will be a thin metal washer/shim over the seal. Pluck the seal and you will see the needle bearing. You can usually use a screwdriver or small punch to implode it a little and pull it up and out. COUNT THE AMOUNT OF NEEDLES IN THE BEARING AND AFTER YOU PULL IT OUT. They tend to fall apart and can easily be retrieved with a magnet. If your arm bent up you may also need a new cable. Also don't forget to adjust the adjuster on the pressure plate. Quote
hondaracing02 Posted February 10, 2015 Author Report Posted February 10, 2015 What rod & ball are you referring to? On clutch side or arm side of motor? So the washer sits between the spring/coil and the seal? Above motor? Don't think it had one of those... What would be the reasoning for a new cable? And how do you adjust pressure plate? Thanks!!! Quote
Larry's Shee Posted February 10, 2015 Report Posted February 10, 2015 Free clue: Clymers Repair Manual. Quote
oldskool Posted February 10, 2015 Report Posted February 10, 2015 There's a service manual on here that can be downloaded. You are going to need it or a Clymers. The push rod and ball come out clutch side of motor(right). You have to pull clutch cover to get to pressure plate. Ezzzy Quote
hondaracing02 Posted February 11, 2015 Author Report Posted February 11, 2015 I have all the pieces, except can't find the washer/spacer that sits between the seal and spring. Anyone know where to find it on eBay? Quote
sheerider11 Posted February 11, 2015 Report Posted February 11, 2015 fast?One of the site sponsors. F.A.S.T. Quote
sleeper06 Posted February 11, 2015 Report Posted February 11, 2015 Tricked blind bearing remover a must on a complete engine Motion pro one is pretty cheap mine has paid for itself 10 fold Quote
hondaracing02 Posted February 11, 2015 Author Report Posted February 11, 2015 i need a bearing remover? it doestn just pull out? where is this "FAST" based out of? Quote
trickedcarbine Posted February 11, 2015 Report Posted February 11, 2015 Tricked blind bearing remover a must on a complete engine Motion pro one is pretty cheap mine has paid for itself 10 foldNoted, just another fancy tool I better buy. Quote
