Do you have a picture of the leak? Leaking base gasket? There are no screws on a yfz cylinder just 4 head bolts and 2 studs. Don't put any sealer on it just put a new gasket. The only things that take sealer are the case halves
  • Like 1
it dosent let me upload?
http://www.ymotor.com/spa/item/resource/ART95598/image_(5).jpeg
but the leak is right inbetween those two long bolts or studs in this pic. dead center,  is this bad to run it like this?
Edited by lllllBonlllll
I wouldn't run it. Sounds like a head gasket but it shouldn't be oil unless there's another problem maybe coolant. Any smoke while it's running or coolant loss?
It takes a while to start. But I'm thinking that is a carb issue. Once it does start it will throw some smoke out of the exhaust(gytr) just a bit it does stop. The stuff coming out is a jet black liquid
