Whenever I am in nutral and shift down to first gear, i hear a loud noise. The noise sounds like either 2 objects hitting together hard, or maybe an object that is spinning coming in contact with an object that is not. If youve never had/dealt with this problem you probably have no idea what I'm talking about, but I'm hoping someone who has had this problem will see this and knows how to fix. Thanks
I dont know how loud it is but i'm pretty sure mine does the same thing. It could be that your clutch is slipping. I dont think its that big of a deal though. As long as your getting the power to the ground and it goes allright you should be fine.
It isnt that important because its not effecting anything in my clutch. It is just annoying and is quite loud. Still waiting on someone to post that has fixed it before.
Well, I think mine is actually doing the same.....Makes a loud "thunk" going into gear sometimes when hot. My gear oil is clean too....
I am thinking it has something to do with the clutch since sometimes I push in the clutch to push the Shee around and its "stuck in gear"! Even with the clutch pulled it wont move. Then once i finally get it in N it seems to work again :(
GOtta figure out what that is?!!!!!
SOUNDS the same... but i dont have any troubles with the clutch. It is flawless except for the noise. trying to push it with just the clutch pulled still works fine, anyone else out there getting this?
