As i said just bought a 2004 banshee. Motor came in a box... not that big of a problem im a mechanic by trade but new to 2 strokes. It came with a cool head and blown pistons. I wanted to know what pistons i should get for the coolhead. I would slowly like to add more power but nothibg crazy to start. Any ideas? Thanks
If it is a stock stroke motor then you need to figure out what size the cylinders need to be bored out to and have the person boring your cylinders for you order then pistons. I run Wiesco Pro Lites in all my motors they are a little more money but good pistons and worth the money.
They need to measure the cyls, then determine how much material needs to be removed based on damage, oval shaping, scaring etc. in order to get a good bore. Then you order pistons and bore to the piston and desired clearances.
Domes, you will probably have to just mock everything up in order to figure out what you have/need. Sort out which base gasket gets the piston edge situated around the ports where you want it. Then torque the cyls and check them with a good straight edge. Now you can measure deck height. With that dimension you can call a multitude of different guys who can cut you domes.
  • Like 1
Perfect going to to have them bored then get him to just order some pro lites
who is "him" its worth dealing with a reputable shop that works on these motors all the time
  • Like 1
I'd send the cylinders to a builder and let them bore it.  If it needs a bore, they can provide the pistons and bore to match the bore to the pistons.  Then, they can provide the gasket kit and do all the measurements necessary to cut a good set of domes for you.  Custom domes > shelf domes.
Don't just buy some pistons and figure that they'll work.  You may have a gouge that's .5mm deep.  If you purchased .5mm larger pistons, you'll be .5mm short.
But, if you trust the guy you know (and he may do just fine) to do the work properly, go ahead with him.  Make sure he chamfers the cylinders.  The site sponsors have proven that they will do quality work whereas you're taking a chance with some guy that nobody knows.
  • Like 1
Spend a little more and send it to a known builder to do the job. I second the wiseco pro lites. Good pistons for a little more $. There is a lot more power to be had with some porting on your stock cylinders too. This would be a great time to explore this since you have to send them out anyway.
Depends on what you want done. Call around to some of the known builders on here. I had Jay at Illinois Power Sports build my last motor and it turned out real good. Give him a call at 630-365-6722 and pick his brain. He'll give you more input then the rest.
