something werid happen here it is the full DIY review
1. take out the 9 bolts holding the stator cover on lay the cover on the bench
2. then depending which case saver you bought. you might have to remove the front sprocket and chain.
3. now take out the 3 little bolts holding the white plastic cover on an set it aside.
4. put the caser saver on and lock tite the 3 bolts and tightin them down.
5. put the sprocket and chain back on and torque the nut down to 59LB
6. you might have to cut the plastic mold off the inside of stator cover to have it fit on the motor.
7. put the gasket on the stator cover and tighten down the 9 bolts.
8. then go on your merry way.
Can I get a how to for which direction to kick the start lever?
You have to take the pegs and nerf bars off so you can crank it by hand. Keep spinning the lever around with your hand until your bike braps to life.
