My first banshee
I also bought a 13 point sprocket for it which ill install this weekend
Good to see the guy picked right up and that and shot a smart ass remark back at you!
Need a little more info to be able to help you out. You say there is a big lag between the bottom of first gear and the power band but once you hit the power band and if you keep the up in the RPM range how does it run? Have you checked anything on the bike or have you just ridden it?
So as long as i keep rpms high it rides awesome carbs are synchronized and filters look good. How do i adjust the power band as far as the sprocket it was just 10$ so if its not a good idea i wont put it on and get something better
You can not adjust the power band he was just messing with you dude. Sounds like to me your jetting is just off if it is slow coming off the bottom then runs well on top. Best way to answer this is to take one carb off and see what pilot and main jet you have in it right now. Then list all the mods along with the elevation you are running at and we will be able to get your jetting really close to where it should be.
  • Like 1
