That being said, Ive had little luck with hand grips that have the heater in a "pad" that the grip slides over. Seems they always twist, rip the pad, then no worky. I much prefer the ones that have the element in the grip, one keep rivet, some mild glue, and youre set for a long time.
I have an old 87 exciter and it doesn't have a battery. Most old sleds don't. I'm not sure where I would mount a small battery. I already have a box mounted where the stock air box is that holds a set of tools and 2 quarts of 2 stroke oil.
I was referring to the 90's 570 exciters
87 was the first year of the return of the exciter. They ran until 93. In 94 they reintroduced the vmax line which ran until 96. In 97 yamaha caught up with the times and went trailing arm and got away from the TSS. Elect start was an option on most which was why the battery was there. No lights or accs worked unless the sled was running. I do believe (not positive) they are all dc and use a regulator to manage the current.
I called Al's snowmobile and talked to a tech there. They said that any universal heated grip will work on an a/c system. They gave me part numbers PH100 for $35.00 and a thumb warmer LM4500 for $25.00. These would will work on the a/c system. The thumb looks like it would be to big for a atv throttle.
http://www.pollyheaters.com/ph100.htm
