2strokes4u Posted September 12, 2014 Report Posted September 12, 2014 So I went to the strip weekend after labor day to get a time but they had a bunch of cars there since it was a race weekend. Only was able to get one run, then i had some tranny issues.. Bike ran a 6.6 at 92 or 93mph (dont have slip in front of me). 60ft was horrible. 1.56. Tires ran were 18x10x10 A.R. and they did not hook well. They were spinning all through 1st. I ran 17/38 gearing and got out of throttle about 10ft before the finish line. I made some changes before the the track visit. I am now running a +10 swinger and drag axle. I am 200lbs. When i ran the plus 6 stock style swinger (heavier) with stock axle the bike would hook great on the street. Im thinking I need to go back to the +6 so my weight is more over the tires. I will play with the +10 a lil while longer to see if I can get it to hook like before. I did go to alky and drag port also. I purchased 20x8x10 A.R. too see if that will help. Not sure when I will get back to the track but my main focus will be the 60ft time. I want to see what time it will get when it is hooking before i mess with lockup. I will be trying different gear setups as well. 1 Quote
aleyesonme Posted September 12, 2014 Report Posted September 12, 2014 I ran out of gear with 18.5 and 18/38, so I know u running way out of gear....I had to let out way before 10 feet tho....maybe u should try 18 before u do anything else, since u got that far with a 17 Quote
2strokes4u Posted September 12, 2014 Author Report Posted September 12, 2014 Cool, most guys around me are running 17/34 with bigger motors than me. I think 18 in front will put me there or close to it then i can tune with rear. Quote
SlowerThanYou Posted September 12, 2014 Report Posted September 12, 2014 Thanks for sharing your results! IMO, the 10+ swingarm is still to short for the track. The 6+ is correct for the street & I'm sure you know that. Quote
2strokes4u Posted September 12, 2014 Author Report Posted September 12, 2014 yeah the +6 was a beast on the street. I may have to have two setups. One for street and one for track. I run street mostly but the track is growing on me. Quote
2strokes4u Posted December 3, 2014 Author Report Posted December 3, 2014 Update: Visited the track last week and wanted to share some progress. Set up: Went from 18 inch A.R. to 20 inch A.R. (6psi) power Jets opened all the way (it was below 50 degrees) 205lb rider Results: 60ft 1.48 1/8 6.3 mph 102mph With proper tuning of carbs and clutches, I should see better results. Now its time to read the clutch tuning thread 1 Quote
2strokes4u Posted December 3, 2014 Author Report Posted December 3, 2014 gearing was 18/38.....5th gear was stretched out and Im sure I held it longer than I should have. I switched to 36 in the rear but did not get a chance to test it at the track. too many cars and then one leaked fluid the entire length of track...smh. The 36 will give me plenty of pull through the entire 1/8th. Quote
trickedcarbine Posted December 3, 2014 Report Posted December 3, 2014 Update: Visited the track last week and wanted to share some progress. Set up: Went from 18 inch A.R. to 20 inch A.R. (6psi) power Jets opened all the way (it was below 50 degrees) 205lb rider Results: 60ft 1.48 1/8 6.3 mph 102mph With proper tuning of carbs and clutches, I should see better results. Now its time to read the clutch tuning thread Wow man, total testament to tried and true tuning. You gained several tenths on the 60', 3 tenths off the ET, and about 10mph. Good stuff man! 1 Quote
Surfrjag Posted December 3, 2014 Report Posted December 3, 2014 good job at the track I didn't know you had made it into the 100mph club. ha better et and you gained 5lbs! to bad they were so slow cleaning oil off the track. some people... 1 Quote
SlowerThanYou Posted December 4, 2014 Report Posted December 4, 2014 Thanks for sharing your hard earned information, again! 1 Quote
quadgod211 Posted December 4, 2014 Report Posted December 4, 2014 With that +10 you could afford to step up tire size you would get the gear back on top end and less wheel spin on bottom with more rollout... jmo Quote
quadgod211 Posted December 4, 2014 Report Posted December 4, 2014 I was a lil late lol Gotta start reading the hole thing haha Good job dude!! 1 Quote
2strokes4u Posted December 11, 2014 Author Report Posted December 11, 2014 Thanks. I will keep this thread updated as I continue to shoot for better times. Will start tuning the clutch next spring. Quote
BANSHEEBEEFM2M Posted December 12, 2014 Report Posted December 12, 2014 Go 23 inch tires more hook more gear ftw 1 Quote
2strokes4u Posted December 15, 2014 Author Report Posted December 15, 2014 Go 23 inch tires more hook more gear ftw With 23" tires, stock frame and my heavy ass i will be giving that motor hell. Quote
