2strokes4u
Everything posted by 2strokes4u
  1. Jeff and Cody are the first builders that I have dealt with on my banshee. I am very pleased at the work that they have done for me and do not see the need to go elsewhere. Customer service is excellent; from texts, emails or phone calls.Builds will run with the best of them. great team
  2. To answer your question- I use Douglas blue label 10x8 (3+5 offset). If this will be strictly for the street, i would ditch the dirt tires and get street tires.
  3. Please send to 1501 Drury Circle Raymore, MO 64083
  4. Ill take them. Sending paypal
  5. Pictures of drag tank to 336-254-9461
  6. Great seller. Crank arrived as described today. Dnt hesitate to buy parts from this guy
  7. What is weight of bar? I live in Raymore. Price?
  8. How do you pull this off? I was under the impression that you had to purge if you were going to store for a week or more. So the more oil the more time you can let sit up?
  9. Finally made it all the way through this thread. I am excited to put this to use and get better 60ft times.Will post results once I have some.
  10. Is that Piedmont track?
  11. Nice Build Looks good without plastics but rules are rules.
  12. what is stock cylinders' last bore?
  13. I paid about 120 bucks from a local powder coating shop for my frame and T bar. Just depends on who does your work. Its white so no custom powder.
  14. This doesn't answer your question but it may be another option. You can flip tires around to make more narrow. You can also get a blaster axle and flip tires.
  15. With 23" tires, stock frame and my heavy ass i will be giving that motor hell.
  16. Can u pm same info as above in case he doesnt buy
  17. Thanks. I will keep this thread updated as I continue to shoot for better times. Will start tuning the clutch next spring.
  18. condition on cylinders? any port work?
  19. gearing was 18/38.....5th gear was stretched out and Im sure I held it longer than I should have. I switched to 36 in the rear but did not get a chance to test it at the track. too many cars and then one leaked fluid the entire length of track...smh. The 36 will give me plenty of pull through the entire 1/8th.
