Slides backwards causing jetting change?
ETR174
Yeah that's what I was trying to say. Would it running lean there make it hesitate getting into the high RPM's?
Very possible. I'm not a fan of any of the aftermarket needles available for stock csrbs. They are all quite a bit longer than stock ones. ...even at their richest setting, they are longer than stock needles at their leanest setting.
Yeah that's what I'm thinking too. Ok well I will try richening the needle. I was just desperate so I got those. Guess I should get some stocker needles soon. Also I just want to make sure my main is ok. I've done plenty of idle to WOT revvs and there are no problems except that needle. Main is currently a 280.
